The configured Buffer Pool Size for the Port's Queue from H/W is read to calculate the buffer size that would be used. This error message states that retrieval of buffer parameters for port range instance has failed. This may occur when incorrect unit number is passed.
Appropriate value of unit number should be passed in order to retrieve queue's buffer parameters. Collect show tech output and contact technical support with suitable information.
Error
%funct%: Failed to get queue's buffer parameters for port %port% with retCode %retCode%
| Name | Type |
| funct | String |
| port | String |
| retCode | uInt32 |
